Performance parts suppliers
Most suppliers do 29mm inlets valves which should be fine for a trials engine. I have used 32mm A series valves, I turn up a special valve cap and use longer springs, but I guess you could simply shorten them cut a collet groove and use Austin caps suitably modified for double springs. Several people seem to have offered reground cams in the recent past, Pigsty, Vince leek, Alan Raeburn etc, some from Newman's, some done by Mr Bonewell, I have had always very good experience with the latter but I hear good reports about Newman ground cams.
PS, I have an Eltos remote, they are quite nice but heavy and in the 4 speed version they reverse the gate. You can fabricate a remote that is lighter and works just as well if not better.
Performance parts suppliers - by frequentflyer - 10-03-2022, 07:50 PM
RE: Performance parts suppliers - by Ian Williams - 10-03-2022, 08:42 PM
RE: Performance parts suppliers - by Tony Betts - 11-03-2022, 10:34 AM
