Using carbon HT leads with acorn caps...
The leads we had were made up and had the push-on fitting for the spark plug in place. The rubber sleeve was left over from our SM restoration. These are high performance leads and are larger in diameter than standard ones. A bit tight in the acorn but that's better than loose as standard HT lead would be.
Note: The original split washer was used in the acorn end.
RE: Using carbon HT leads with acorn caps... - by AustinWood - 08-03-2022, 10:06 AM
