Fuel Tank Sender Unit
I am not sure if the sender is voltage sensitive, but my Ruby (12 volt ) and the Pearl I am doing at the moment will be 12 volt also, on both I have used a pre 1974 Midget/ Sprite sender , you have to bend the arm down 1/2 inch and mount it so the float is to the right of the tank (from the front ) to avoid the float touching the baffles.
Fuel Tank Sender Unit - by Alan Course - 10-03-2018, 06:30 PM
RE: Fuel Tank Sender Unit - by Ian Williams - 10-03-2018, 07:30 PM
RE: Fuel Tank Sender Unit - by John Cornforth - 10-03-2018, 08:39 PM
RE: Fuel Tank Sender Unit - by Bob Culver - 10-03-2018, 08:32 PM
RE: Fuel Tank Sender Unit - by Zetomagneto - 10-03-2018, 09:36 PM
RE: Fuel Tank Sender Unit - by squeak - 10-03-2018, 11:17 PM
RE: Fuel Tank Sender Unit - by Nigel was in Brittany - 10-03-2018, 09:26 PM
RE: Fuel Tank Sender Unit - by Alan Course - 14-03-2018, 10:00 PM
RE: Fuel Tank Sender Unit - by Andy Bennett - 18-03-2018, 08:32 PM
