Chassis shortening
(10-03-2018, 08:08 PM)Zetomagneto Wrote:
(10-03-2018, 12:29 PM)John Bonnett Wrote: Thank you all for you replies which have been enormously helpful.
Bryan has done a very fine job with the splicing; beautifully executed with so much room for error. A chassis jig would certainly be necessary. The finished result is excellent. However, chopping off sections from the rear of the chassis rails is apparently a lot more straightforward and simple to do and I like simple. Just a question of making up axle mounts and shortening the longitudinal member.
John
Jon, just wondering if you would buy a cut & Shut car.Something to think about!
Probably not but that's what stretched limos are so I suppose if done properly they have to be sound. If I do shorten the chassis it will be chopping off the ends because that is much simpler and I'm all for an easy life.
Chassis shortening - by John Bonnett - 09-03-2018, 02:31 PM
RE: Chassis shortening - by Bryan Norfolk - 09-03-2018, 03:03 PM
RE: Chassis shortening - by John Bonnett - 09-03-2018, 03:22 PM
RE: Chassis shortening - by Zetomagneto - 09-03-2018, 08:16 PM
RE: Chassis shortening - by Bryan Norfolk - 09-03-2018, 03:33 PM
RE: Chassis shortening - by Steve Jones - 09-03-2018, 04:02 PM
RE: Chassis shortening - by Hedd Jones - 09-03-2018, 05:00 PM
RE: Chassis shortening - by John Bonnett - 09-03-2018, 05:19 PM
RE: Chassis shortening - by JonE - 09-03-2018, 08:53 PM
RE: Chassis shortening - by Peter Naulls - 09-03-2018, 09:47 PM
RE: Chassis shortening - by John Bonnett - 10-03-2018, 12:29 PM
RE: Chassis shortening - by Zetomagneto - 10-03-2018, 08:08 PM
RE: Chassis shortening - by John Bonnett - 10-03-2018, 08:15 PM
