  • 1 Vote(s) - 4 Average
Semi Girling front hubs
Tony, I completely agree. The n/s with the play is what I would expect since when everything is installed, there is very little play left. I suspect the issue lies with the bearing on the o/s which doesn't have nay play at all. The issue is that while it doesn't bind, I believe that it should have some play as there will be a build up of heat. In the end, I've ordered two sets of bearings and will replace at least the o/s. Even with my Minis, I remember backing off a bit after tightening. I just don't like a bearing that while not binding, doesn't spin as freely as it should. Personally, I don't think there is anything wrong with the Austin design. My motorcycles always just had caged ball bearings.
Erich in Mukilteo
Semi Girling front hubs - by Erich - 24-02-2022, 05:58 AM
RE: Semi Girling front hubs - by Bob Culver - 24-02-2022, 07:47 AM
RE: Semi Girling front hubs - by Erich - 24-02-2022, 07:56 AM
RE: Semi Girling front hubs - by Bob Culver - 24-02-2022, 08:24 AM
RE: Semi Girling front hubs - by Tony Press - 24-02-2022, 09:56 AM
RE: Semi Girling front hubs - by Erich - 24-02-2022, 04:09 PM
RE: Semi Girling front hubs - by Terrytuned - 24-02-2022, 06:00 PM
RE: Semi Girling front hubs - by Bob Culver - 24-02-2022, 07:15 PM
RE: Semi Girling front hubs - by Erich - 24-02-2022, 11:00 PM
RE: Semi Girling front hubs - by Tony Press - 25-02-2022, 02:00 AM
RE: Semi Girling front hubs - by Bob Culver - 25-02-2022, 02:14 AM
RE: Semi Girling front hubs - by Tony Press - 25-02-2022, 02:37 AM
RE: Semi Girling front hubs - by Dennis Nicholas - 25-02-2022, 02:30 PM
RE: Semi Girling front hubs - by Bob Culver - 25-02-2022, 04:26 PM
RE: Semi Girling front hubs - by Dennis Nicholas - 25-02-2022, 05:10 PM
RE: Semi Girling front hubs - by Erich - 25-02-2022, 07:14 PM
RE: Semi Girling front hubs - by Dennis Nicholas - 26-02-2022, 08:10 PM
RE: Semi Girling front hubs - by Erich - 26-02-2022, 10:00 PM
RE: Semi Girling front hubs - by Tony Press - 26-02-2022, 10:09 PM
RE: Semi Girling front hubs - by Erich - 27-02-2022, 03:06 AM
RE: Semi Girling front hubs - by Dennis Nicholas - 28-02-2022, 12:58 PM
RE: Semi Girling front hubs - by Bob Culver - 28-02-2022, 03:22 PM
RE: Semi Girling front hubs - by Tony Press - 01-03-2022, 12:54 AM
RE: Semi Girling front hubs - by Bob Culver - 01-03-2022, 03:51 AM
RE: Semi Girling front hubs - by Dennis Nicholas - 07-03-2022, 05:13 PM
