  • 1 Vote(s) - 4 Average
Semi Girling front hubs
A couple of items.
If the inner large bearing is still a good fit on the stub shaft and in the felt carrier the 1/16" wobble in the felt carrier is the  internal movement in the bearing (magnified at the rim of the felt carrier).
The internal clearance in a bearing is the radial clearance - if the ball groove radius in the bearing rings is larger than the ball diameter then the rings can move axially even with a small internal clearance. This is not a problem with the outer ball bearing keeping the hub upright.
The hub housing design is made for a pair of ball bearings. If taper roller bearings were installed the housing would have a quite different design.
Austin Seven hubs have survived for 100 years - if you want a car with taper roller bearing hubs then buy a different car.
Most modern cars now have hub units which usually use ball bearings.
.jpg   Modern Car Front Hub.JPG (Size: 20.71 KB / Downloads: 102)
Semi Girling front hubs - by Erich - 24-02-2022, 05:58 AM
RE: Semi Girling front hubs - by Bob Culver - 24-02-2022, 07:47 AM
RE: Semi Girling front hubs - by Erich - 24-02-2022, 07:56 AM
RE: Semi Girling front hubs - by Bob Culver - 24-02-2022, 08:24 AM
RE: Semi Girling front hubs - by Tony Press - 24-02-2022, 09:56 AM
RE: Semi Girling front hubs - by Erich - 24-02-2022, 04:09 PM
RE: Semi Girling front hubs - by Terrytuned - 24-02-2022, 06:00 PM
RE: Semi Girling front hubs - by Bob Culver - 24-02-2022, 07:15 PM
RE: Semi Girling front hubs - by Erich - 24-02-2022, 11:00 PM
RE: Semi Girling front hubs - by Tony Press - 25-02-2022, 02:00 AM
RE: Semi Girling front hubs - by Bob Culver - 25-02-2022, 02:14 AM
RE: Semi Girling front hubs - by Tony Press - 25-02-2022, 02:37 AM
RE: Semi Girling front hubs - by Dennis Nicholas - 25-02-2022, 02:30 PM
RE: Semi Girling front hubs - by Bob Culver - 25-02-2022, 04:26 PM
RE: Semi Girling front hubs - by Dennis Nicholas - 25-02-2022, 05:10 PM
RE: Semi Girling front hubs - by Erich - 25-02-2022, 07:14 PM
RE: Semi Girling front hubs - by Dennis Nicholas - 26-02-2022, 08:10 PM
RE: Semi Girling front hubs - by Erich - 26-02-2022, 10:00 PM
RE: Semi Girling front hubs - by Tony Press - 26-02-2022, 10:09 PM
RE: Semi Girling front hubs - by Erich - 27-02-2022, 03:06 AM
RE: Semi Girling front hubs - by Dennis Nicholas - 28-02-2022, 12:58 PM
RE: Semi Girling front hubs - by Bob Culver - 28-02-2022, 03:22 PM
RE: Semi Girling front hubs - by Tony Press - 01-03-2022, 12:54 AM
RE: Semi Girling front hubs - by Bob Culver - 01-03-2022, 03:51 AM
RE: Semi Girling front hubs - by Dennis Nicholas - 07-03-2022, 05:13 PM
