CW & P ratios
I have never seen a roller bearing with an extended inner ring ???
I would think it unlikely that Austins would have had this made. The material does not look like bearing steel.
Not sure but something doesn't seen correct.
Getting back to the question-  as suggested the ball bearing would probably do the job now although the roller is a better solution (as Austins found out).
You will need a new spacer as well.
CW & P ratios - by Nick Mayne - 20-02-2022, 03:49 PM
RE: CW & P ratios - by Jack in the Box - 20-02-2022, 04:31 PM
RE: CW & P ratios - by Parazine - 20-02-2022, 05:08 PM
RE: CW & P ratios - by JonE - 20-02-2022, 08:42 PM
RE: CW & P ratios - by Nick Mayne - 20-02-2022, 09:17 PM
RE: CW & P ratios - by dickie65 - 20-02-2022, 09:54 PM
RE: CW & P ratios - by Bob Culver - 20-02-2022, 11:17 PM
RE: CW & P ratios - by Parazine - 21-02-2022, 10:29 AM
RE: CW & P ratios - by Nick Mayne - 21-02-2022, 01:15 PM
RE: CW & P ratios - by Parazine - 22-02-2022, 12:46 AM
RE: CW & P ratios - by Nick Mayne - 22-02-2022, 12:52 AM
RE: CW & P ratios - by Bob Culver - 22-02-2022, 04:52 AM
RE: CW & P ratios - by Nick Mayne - 24-02-2022, 05:19 PM
RE: CW & P ratios - by andrew34ruby - 24-02-2022, 05:38 PM
RE: CW & P ratios - by Parazine - 24-02-2022, 06:53 PM
RE: CW & P ratios - by Tony Press - 24-02-2022, 10:38 PM
RE: CW & P ratios - by Nick Mayne - 01-03-2022, 10:48 PM
RE: CW & P ratios - by Bob Culver - 01-03-2022, 11:40 PM
RE: CW & P ratios - by Parazine - 02-03-2022, 12:10 AM
RE: CW & P ratios - by Stuart Giles - 02-03-2022, 12:32 PM
RE: CW & P ratios - by dickie65 - 02-03-2022, 06:51 PM
