Chassis Packing
I think a lot of patience, and going away," having a think" and coming back for another go is required.
My only experience of this, so far, is fitting a replica Cambridge body - so just one small construction, without doors.
The body was dimensionally to within 3mm of the original, and was being mated with an existing front end.
I still haven't got it right, gave up in the end and packed up the bonnet top with a 25mm to nothing wooden wedge where bonnet meets the body sides.   Horrible, I know, but I had to get the car to a wedding.
Though I didn't have doors to worry about, I had other points to line up: the angle of the front body panels, the height of the body top above the chassis at the front and the rear, the fore and aft position which in turn affected the position of the seats.
The nearest thing to a "fixed" point was the steering column clamp, and the next was the clearance of the body over the rear springs.   This last is a particularly Cambridge problem, the timbers have to be shaved away a bit  - but not too much.
Although it got a result, packing the cow horns doesn't "feel" right.   In an ideal world I would have the body loosely attached at the cow horns - the known "fixed" point, and have movable up/down things (4 or 6 off bottle jacks???)
at the other mounting points.   Then play with combinations of positions and see what is the best compromise you can get.
Good luck
Simon
Chassis Packing - by Matt_Harnden - 30-12-2017, 06:27 PM
RE: Chassis Packing - by Matt_Harnden - 31-12-2017, 02:23 PM
RE: Chassis Packing - by squeak - 31-12-2017, 03:41 PM
RE: Chassis Packing - by Matt_Harnden - 01-01-2018, 12:30 PM
RE: Chassis Packing - by Martin Prior - 31-12-2017, 07:37 PM
RE: Chassis Packing - by Matt_Harnden - 01-01-2018, 02:16 PM
RE: Chassis Packing - by JonE - 01-01-2018, 12:53 PM
RE: Chassis Packing - by Matt_Harnden - 06-01-2018, 06:08 PM
RE: Chassis Packing - by squeak - 07-01-2018, 12:30 AM
RE: Chassis Packing - by Phil Kingdom - 07-01-2018, 01:36 AM
RE: Chassis Packing - by Matt_Harnden - 21-01-2018, 07:00 PM
RE: Chassis Packing - by Ruairidh Dunford - 08-03-2018, 09:21 AM
RE: Chassis Packing - by "Slack Alice" Simon - 08-03-2018, 02:40 PM
RE: Chassis Packing - by Matt_Harnden - 13-03-2018, 11:06 PM
