A7 19" wheel run-out
Depends a bit on the type of wander. A slow wander over whole wheel and same both sides more noticeable than a quick mainly one sided kink due some past incident, as this affects tyre less.
Main thing is spokes not loose and working in the centres and rim. If nipples rusted up adj can be fraught, esp if the long spokes cannot be replaced without removing the centre. Striking the nipple bodies between two surfaces may break rust.
Wandering rims confuse toe in. A centre line can be scribed by using a pointed hacksaw blade sprung horizontal on its side to scribe a track around the tyre.
A7 19" wheel run-out - by Nick Mayne - 13-02-2022, 06:14 PM
RE: A7 19" wheel run-out - by Tiger - 14-02-2022, 09:24 AM
RE: A7 19" wheel run-out - by Colin Morgan - 14-02-2022, 01:27 PM
RE: A7 19" wheel run-out - by andrew34ruby - 14-02-2022, 01:59 PM
RE: A7 19" wheel run-out - by Howard Wright - 14-02-2022, 02:27 PM
RE: A7 19" wheel run-out - by andrew34ruby - 14-02-2022, 04:05 PM
RE: A7 19" wheel run-out - by AustinWood - 14-02-2022, 04:25 PM
RE: A7 19" wheel run-out - by Bob Culver - 14-02-2022, 08:33 PM
RE: A7 19" wheel run-out - by Nick Mayne - 16-02-2022, 07:22 PM
RE: A7 19" wheel run-out - by dickie65 - 17-02-2022, 08:00 PM
