I've been busy with Davids old car, plus a job or two on the grey saloon
Put some miles on TH since its engine transplant. Now done nearly 30miles. Goes well enough. It is a little smokey from the valve chest, but hey ho. At least its running and on the road while its proper engine is in bits. A breather pipe has already solved that problem. Will drop the oil in it next time I get it warm.
[Image: 273974112_10225004754560613_298347645280...e=620D2165]
also fixed the puncture. There was an inch and a half gash in the tube!. Had to make my own patch
[Image: 273885737_10224999601671794_876295061772...e=620C9A40]
David, a question for you, ever since ive known the car, the bloody pedals have fallen off whilst driving. The cones are brazed to the pad, and have a rubber pad, so they eventually come undone and fall off. This is a thorough PITA
[Image: 273894369_10224999600631768_479730369244...e=620C5478]
My grey car is pukka Austin and only very occasionally have I had this problem. However on the chummy I not long sold the pads were secured with nuts. That seemed to be the permanent cure. So have done this similar and sodded off the pedal rubbers to boot.
[Image: 273890307_10224999599071729_272757482733...e=620D20C2]
I noticed a drop of coolant on the head of the grey car the other day, looks like the joint under the water manifold was kaput, so took it off, cut a new one. refitted with a new fibre washer etc. Also noticed the hose wasn't the best so invested in a new one. Now back together and full of antifreeze again. So all 3 cars back on the road.
[Image: 273676554_10224988079543748_657546449612...e=620D3A9F]
[Image: 273679529_10224988080223765_463223265349...e=620C8F74]
[Image: 273851296_10225003530090002_409561946697...e=620D844C]
Next job is to take the chummy to bits!
RE: What have you done today with your Austin Seven - by Hedd_Jones - 12-02-2022, 08:47 PM
Users browsing this thread: 1 Invisible User(s), 9 Guest(s)
