11-02-2022, 01:21 PM
Hi Frequentflyer
I’m no expert in engine tuning nor on trials but as no one has responded here are my suggestions
Head….Dave Dye sells alloy Ricardo heads which seem to have a good reputation. I have one on my Special and it goes well.
Carb…..SU is the route to go IMHO. You probably don’t need more than an 1 1/8” although on my Special a 1 1/4” H2 seems to work well.
Flywheel…There is a good section in the A7 companion on flywheel lightening. I’ve gone half way on the suggestions.
Clutch…Stiffer springs may help but I’ve got standard ones on my Special.
Cam……I’m using a standard cam but Paul Bonewell is the man to talk to if you want good advice.
Hope that helps?
Hope that helps?
