Rear axle droning noise
I have successfully skimmed the mounting face on an A7 diff where there was axial run out caused by a previous pinion failure -that diff had about .005" TIR -The diff was running between centres in a lathe when I skimmed it. I think that having any run out there would make it difficult to get a consistent pattern when setting up the mesh and depth of engagement.
Did you check the pattern with engineers blue or chrome yellow when you built it up? With a well used CW & P I have found that getting a good pattern is the best way to get silent/quiet running; setting it up according to the book/numbers etched on the pinion etc. is going to lead to the CW & P pair running on high spots if that setting doesn't match what's been happening with the gear setup for thousands of miles previous.
Rear axle droning noise - by Tattybogle - 06-03-2018, 01:09 PM
RE: Rear axle droning noise - by Nick Turley - 06-03-2018, 03:13 PM
RE: Rear axle droning noise - by AustinWood - 06-03-2018, 03:22 PM
RE: Rear axle droning noise - by Nick Lettington - 06-03-2018, 10:51 PM
RE: Rear axle droning noise - by Bob Culver - 07-03-2018, 06:13 AM
RE: Rear axle droning noise - by Ian Williams - 07-03-2018, 06:48 AM
RE: Rear axle droning noise - by Stuart Giles - 07-03-2018, 12:44 PM
RE: Rear axle droning noise - by Nick Lettington - 07-03-2018, 02:15 PM
RE: Rear axle droning noise - by Tattybogle - 07-03-2018, 12:44 PM
