08-02-2022, 11:25 AM
HI DAVID,
A Couple of THINGS, how did you put a highly tuned Engine together with out Knowing the volume of the head.
the oil on the top of the pistons could be bores being glazed so you will need to check bore size just below where the top ring comes to .
You will also have to pull engine out to rectify the loose flywheel because if you do manage to get it to rev you are very likely to end up with a very expensive repair Bill.
just take your time and check every thing from scratch.
All the Best
COLIN
NZ
All the Best
COLIN
NZ
