Rear brake bush
Thank you both for your replies .
Parazine I will give that a go , I hope to do it with the axle in place.
Howard I have a set of bushes which I have already fitted to the front however the hole on the rear axle is too small to take the same bushes .
I understand the perforated bush I removed to be a smaller variant and no longer available from looking at another thread.
Rear brake bush - by Gaz747 - 06-02-2022, 09:46 AM
RE: Rear brake bush - by Parazine - 06-02-2022, 11:10 AM
RE: Rear brake bush - by Howard Wright - 06-02-2022, 12:38 PM
RE: Rear brake bush - by Gaz747 - 06-02-2022, 01:06 PM
RE: Rear brake bush - by Ivor Hawkins - 06-02-2022, 01:27 PM
RE: Rear brake bush - by Gaz747 - 06-02-2022, 01:54 PM
RE: Rear brake bush - by Howard Wright - 06-02-2022, 02:20 PM
RE: Rear brake bush - by Jamie - 06-02-2022, 05:01 PM
RE: Rear brake bush - by Ian Williams - 06-02-2022, 09:56 PM
