06-03-2018, 10:21 PM
(This post was last modified: 06-03-2018, 10:39 PM by Colin Wilks.
Edit Reason: Adjust bore size.
If the o/d is 1" the hose is probably SAE 100R6 -10, which is 5/8ths inch bore low pressure oil hose reinforced with a single textile braid. Hydraulic hose bore is sized in "dash" sizes of 1/16th of an inch, so dash 10 is 10/16ths or 5/8ths inch etc. Any hydraulic hose trade counter will give you an offcut if you ask nicely.
