27-01-2022, 02:49 PM
The pictures don't show my actual carb which is slightly earlier.
The plan is to revert back to the early exhaust manifold then just swap the inlet manifold and carb in and out.
With the current set up, with the Ruby manifold, the SWB exhaust pipe has been cut and shut to fit the slightly different exhaust exit position. This modified pipe clashes with the standard flitch panels I have installed so going back to the standard pipe would be neater.
The craziness of changing one thing and it effects half a dozen others.
I friend has offered me a welded up "updraft manifold modified into a side draft" one, and my Dad has a early manifold tucked away somewhere so I think I should have all of the bits.
I couldn't possibly comment on whether I would modify the updraft Zenith which would be used on Light car events.
Thanks all.
Tom
Thanks all.
Tom
