  • 1 Vote(s) - 1 Average
Jacking point(s)
I'm going to be removing the rear wheels on my Ulster rep and wonder what others do when using a trolley jack to lift the rear of the car. I'm rather reluctant to use the diff housing as I would on a modern. Can a beam be laid across the jack to hit the frame rails without fouling the prop shaft? I just need it jacked up enough that I can put jack stands under the axle, unless there is another recommended placement for the latter.
Erich in Seattle.
Jacking point(s) - by Erich - 05-03-2018, 06:15 AM
RE: Jacking point(s) - by Dave Wortley - 05-03-2018, 08:19 AM
RE: Jacking point(s) - by Tony Press - 05-03-2018, 11:45 AM
RE: Jacking point(s) - by dickie65 - 05-03-2018, 08:06 PM
RE: Jacking point(s) - by Steve kay - 06-03-2018, 09:57 AM
RE: Jacking point(s) - by John Mason - 06-03-2018, 11:12 AM
