04-03-2018, 05:02 PM
I have a block (M163594) fitted with the later cover with a triangular groove for the gasket. The cork replacement is square section....do I have to attack it (carefully) and trim it to a triangular section or (unlikely I think) if I fit it over the groove and hope it stays in place and is squeezed into place....I don't think it will fit with the square section angled into the groove & the opposite angle forming a seal of sorts against the block
Can it be softened to force it into the groove?
Is it the wrong part?
When I removed the tappet cover it had the remains of both a carbonised gasket in the groove together with a flat gasket around the periphery of the tappet chest.
David
David
