Enot vs Jubilee?.
Another tip when considering fitting hoses to cast parts is to smooth out any cast parts that stick up above the rounded surface (especially new castings) and for rough corroded ones just clean thoroughly and smother with JB Weld then make round again with strips of abrasive cloth part wraped round and pulled back and forth by the ends.......then the clamps of choice will stand a better chance of sealing with only moderate or low pressure applied.  Obvious I know but I struggled to get water tight a new casting .....in a difficult position on another make car Austin related......till I finally gave up and removed casting and fettled it as above as I should have done in the first place.
Dennis
Enot vs Jubilee?. - by Denis Sweeney - 05-01-2022, 04:46 PM
RE: Enot vs Jubilee?. - by Stumpi - 05-01-2022, 05:23 PM
RE: Enot vs Jubilee?. - by dickie65 - 05-01-2022, 05:25 PM
RE: Enot vs Jubilee?. - by Hugh Barnes - 05-01-2022, 05:26 PM
RE: Enot vs Jubilee?. - by Denis Sweeney - 05-01-2022, 05:37 PM
RE: Enot vs Jubilee?. - by John Cornforth - 05-01-2022, 06:43 PM
RE: Enot vs Jubilee?. - by Reckless Rat - 05-01-2022, 07:17 PM
RE: Enot vs Jubilee?. - by David Stepney - 05-01-2022, 09:27 PM
RE: Enot vs Jubilee?. - by Charles P - 05-01-2022, 09:44 PM
RE: Enot vs Jubilee?. - by Dennis Nicholas - 06-01-2022, 08:02 PM
RE: Enot vs Jubilee?. - by Peter Sweeney - 07-01-2022, 01:11 PM
RE: Enot vs Jubilee?. - by Mike Wood - 29-01-2022, 08:16 AM
RE: Enot vs Jubilee?. - by Ian Williams - 29-01-2022, 10:18 PM
