chassis and the metal they are made from.
Well I cut my chassis in half,!! you can see the photos in FB in the specials page.
I then did a spark test on a part of the chassis. I then compared to a bit of
carbon steel I had laying around and they are the same. So with out doing a DT to find out the exact mix that's good enough.
As for welding 309 filler rod and a blue tip tungsten and off you go. Preheat as well just to be on the safe side
RE: chassis and the metal they are made from. - by Mike Moule - 04-03-2018, 01:26 PM
