Block fitting
(04-01-2022, 06:45 PM)Parazine Wrote: So the real question:
Does anyone have any other favorite ways to fit the block? Yes, I know the oil baffles are optional and life would have been simpler without them........
If the motor has an 1 5/16" or early crank I fit the empty block to the crankcase with the oil baffles in place but cut with a pair of tin snips such that they can be prised open with your fingers.  If the motor has been bored, most unmodified 1 5/16" rods will pass down the bores OK. In any case, when I balance the rods, I make sure that I take metal off the big end 'dimples' you can see in this photo.
[Image: 43889484145_316e2bed74_z.jpg]
Once all the big ends are bolted up the oil baffles can be pushed back in place with your fingers and you're good to go.
Block fitting - by Parazine - 04-01-2022, 06:45 PM
RE: Block fitting - by dickie65 - 04-01-2022, 07:38 PM
RE: Block fitting - by Reckless Rat - 04-01-2022, 08:01 PM
RE: Block fitting - by Ruairidh Dunford - 04-01-2022, 09:09 PM
RE: Block fitting - by Hugh Barnes - 04-01-2022, 09:09 PM
RE: Block fitting - by Parazine - 04-01-2022, 11:24 PM
RE: Block fitting - by Bob Culver - 05-01-2022, 05:02 AM
RE: Block fitting - by Hedd_Jones - 05-01-2022, 08:56 AM
RE: Block fitting - by Stuart Giles - 05-01-2022, 11:35 AM
RE: Block fitting - by John Mason - 05-01-2022, 12:34 PM
