FRONT HUB LIP SEAL
The larger metric bearing you mention 35mm x 72mm x 17mm would have been R&M LJ35 / S.K.F 6207 - it was apparently used in the rear hubs of the Big Seven from chassis number 7841. This LJ35 bearing was also used in the rear hubs of the Austin 8 from 1938 to 1947.
My bearing catalogue also notes that Big 7's from chassis number 7841 the two differential bearings changed from R&M LJT 1.1/4" / S.K.F ALS10A to R&M LJT 1.3/8" / S.K.F ALS11A.
FRONT HUB LIP SEAL - by Dennis Nicholas - 02-01-2022, 08:41 PM
RE: FRONT HUB LIP SEAL - by Bob Culver - 02-01-2022, 09:58 PM
RE: FRONT HUB LIP SEAL - by Dennis Nicholas - 04-01-2022, 06:24 PM
RE: FRONT HUB LIP SEAL - by Denis Sweeney - 04-01-2022, 07:23 PM
RE: FRONT HUB LIP SEAL - by Tony Betts - 04-01-2022, 07:56 PM
RE: FRONT HUB LIP SEAL - by Jeff Taylor - 04-01-2022, 07:58 PM
