04-01-2022, 07:56 PM
hi dennis,
the bearing od in the hub didnt change.
the change in part numbers is to cover the drum moving onto full girling. the ones without location pegs. they had a larger ID were they fit the hub. SO the full girling hubs have a lip. the part number changes are to covers this lip.
i dont recognise the seal part number you give, unless this is a suppliers list number.
i used to supply modern lip seals, but stopped when everyone else started stocking. there isnt a problem in useing them if they are still being offered in the correct size. they were always supplied in metric. so likely to be 4 thou over on the OD. but they were always a rubber coated seals. so they were tight. but pressed in fine with some grease to ease them.
ive moved on from useing this method nowadays, and use a far easier better method.
tony.
tony.
