03-01-2022, 10:28 AM
(This post was last modified: 03-01-2022, 10:29 AM by Stuart Giles.
Edit Reason: typo
(03-01-2022, 03:31 AM)Graham Barker Wrote: The descriptions from Woodrow and others of refurbishing a diff make it sound to be a very tedious undertaking. I am not keen on that. Maybe I should "run it til it busts"?
The silver flakes are most likely from the crownwheel or pinion; so there is likely to be some damage already. 'Running it till it busts' means that the CW & P will definitely need replacing - around £400 for a new one, finding a decent secondhand one and setting it up to run quietly in your axle case might be a bit of a mission. Or you could buy a complete Girling rear axle and hope that it's better than yours; personally I would rebuild the existing axle, not a cheap option with all those bearings to buy, but at least you know that it's a job properly done.
