FRONT HUB LIP SEAL
Oh dear! Seal will not fit in.
Front Hub Felt Housing A3-39 taking bearing 2K5507 (BL63)(listed also BO89 on back axle) size 1 1/4" X 2 3/4" X 11/16" as fitted late A7 and Big 7.  Felt rings in spares list 2K6759.
A couple of years ago I got the a7c lip seals BL62a (says 1926 - 1939) ready to fit during my big rebuild. Size 1.5 X 2.5 X 3/8.  I have now just tried to fit one and find it is extremely reluctant to fit in fact even with an exact fit socket/tube to push it in with I feel it would need too much pressure possibly distorting the whole thing.  I have resorted to, at first,  all round hammer taping on back/base ring with a blunt drift, then even harder blows but no progress and fear I may have possibly distorted the seal too much for it to be of any use.
Has anyone else tried fitting BL62a and if you succeed how?  How much pressure?  (One person I phoned who is good with engineering and A7s had same problem and overcame by mounting felt carrier in lathe and skimming a small amount off till new seal went in but with enough friction to hold it tight.....I don't like modifying parts like that in view of future problem possible with correct size seals being then too small so free to rotate)
Using a micrometer, With difficulty on the felt items, I have the following O/D sizes:-
New BL62a lip seal   O/D 2.502 to 2.509 inches
Old lip seal that I took out and was a good fit - with metal outer that had no rubber around outside and was marked RTB1179 - 2.483 to 2.489
An old felt seal that was good push fit - O/D 2.485
A new felt seal that fits snugly - O/D - 2.4835
second new felt.                       O/D - 2.495
This seems to indicate that the BL62a is really too large to be able to force in??  The Jan 1946 spares list shows the same A3-39 felt housing and felt ring  2K6759 and bearing 2K5507 continues.
Being ready for centenary run seems to be looking a bit dodgy!
Dennis
FRONT HUB LIP SEAL - by Dennis Nicholas - 02-01-2022, 08:41 PM
RE: FRONT HUB LIP SEAL - by Bob Culver - 02-01-2022, 09:58 PM
RE: FRONT HUB LIP SEAL - by Dennis Nicholas - 04-01-2022, 06:24 PM
RE: FRONT HUB LIP SEAL - by Denis Sweeney - 04-01-2022, 07:23 PM
RE: FRONT HUB LIP SEAL - by Tony Betts - 04-01-2022, 07:56 PM
RE: FRONT HUB LIP SEAL - by Jeff Taylor - 04-01-2022, 07:58 PM
