Differential Adjustment
Hi Graham
I believe that the adjusters are really only there to get the CW&P set up correctly when rebuilding the axle.  As Bob says nothing is set in stone and I have, in the past, adjusted an axle slightly in situ albeit with little change in axle noise  Smile.
However unless the noise is unbearable (when a full rebuild is needed) I’d leave well alone.
Drain the oil and refill sparingly.
Differential Adjustment - by Graham Barker - 02-01-2022, 12:13 AM
RE: Differential Adjustment - by Bob Culver - 02-01-2022, 02:10 AM
RE: Differential Adjustment - by Howard Wright - 02-01-2022, 10:31 AM
RE: Differential Adjustment - by Parazine - 02-01-2022, 12:29 PM
RE: Differential Adjustment - by Nick Turley - 02-01-2022, 01:44 PM
RE: Differential Adjustment - by Stuart Giles - 02-01-2022, 01:52 PM
RE: Differential Adjustment - by Jack in the Box - 02-01-2022, 03:50 PM
RE: Differential Adjustment - by Graham Barker - 03-01-2022, 03:31 AM
RE: Differential Adjustment - by Stuart Giles - 03-01-2022, 10:28 AM
RE: Differential Adjustment - by Graham Barker - 03-01-2022, 11:48 PM
RE: Differential Adjustment - by Bob Culver - 04-01-2022, 01:12 AM
RE: Differential Adjustment - by Graham Barker - 04-01-2022, 09:49 AM
