Genuine Ulster floor supports
Thank you Henry. What is curious, is that the rivets on the floor(not the angled firewall bit) must have been outside the where the chassis supports connect with the floor. Otherwise, the rivets would prevent the chassis supports from properly supporting the floor. The vertical part of the firewall is curious as it appears to be a reversed bit as the slot would appear to have been from a pedal, such as the throttle pedal.
Erich in Mukilteo
Genuine Ulster floor supports - by Erich - 31-12-2021, 12:53 AM
RE: Genuine Ulster floor supports - by Erich - 02-01-2022, 07:13 AM
RE: Genuine Ulster floor supports - by JonE - 02-01-2022, 11:09 AM
