29-12-2021, 05:34 PM
Ian, on my Marine tourer special I have mudguard mounted side/indicator lights with leds. In the headlights I also have amber indicator bulbs instead of the normal reflector mounted sidelights , also leds. The mudguards are cycle type that are body mounted and don't turn. At the rear the tail lights have twin filament leds for side/indicators/brake lights, controlled by a series of relays. A central rear light is also a tail/ brake/rear fog light also led and controlled by a relay. I'll put a circuit diagram for the front/rear/indicator/brake control for your entertainment.One thing to remember is the front sidelamp fittings in the m'guards do reduce the available suspension movement.
