rear axle casing bend?
Hello Jon just returned from the Christmas shop, but Stuart’s illustration pretty much shows the set up, with the ratchet strap hard up against the backplate (chain recommend if using oxy acetylene!) then the bottle jack and the other strap about nine inches further along the axle towards the diff.
I used a four inch length of scaffold pole sliced in half between the bottle jack and the axle do it didn’t kink and straightened the axle cold and used the half shaft to gauge when the axle was straight....it was by no means precision engineering, but it worked!
rear axle casing bend? - by JonE - 21-12-2021, 04:27 PM
RE: rear axle casing bend? - by Howard Wright - 21-12-2021, 04:51 PM
RE: rear axle casing bend? - by Malcolm Parker - 21-12-2021, 05:11 PM
RE: rear axle casing bend? - by Stuart Giles - 21-12-2021, 06:20 PM
RE: rear axle casing bend? - by JonE - 21-12-2021, 06:50 PM
RE: rear axle casing bend? - by Reckless Rat - 21-12-2021, 06:55 PM
RE: rear axle casing bend? - by Bob Culver - 21-12-2021, 07:44 PM
RE: rear axle casing bend? - by Ruairidh Dunford - 21-12-2021, 07:46 PM
RE: rear axle casing bend? - by Steve Jones - 21-12-2021, 08:02 PM
RE: rear axle casing bend? - by JonE - 21-12-2021, 08:47 PM
RE: rear axle casing bend? - by Ivor Hawkins - 21-12-2021, 10:25 PM
RE: rear axle casing bend? - by Bob Culver - 22-12-2021, 03:36 AM
RE: rear axle casing bend? - by JonE - 22-12-2021, 10:52 AM
RE: rear axle casing bend? - by Reckless Rat - 22-12-2021, 11:16 AM
RE: rear axle casing bend? - by Hedd_Jones - 22-12-2021, 11:51 AM
RE: rear axle casing bend? - by Stuart Giles - 22-12-2021, 12:04 PM
RE: rear axle casing bend? - by JonE - 22-12-2021, 02:02 PM
RE: rear axle casing bend? - by Ivor Hawkins - 22-12-2021, 04:26 PM
RE: rear axle casing bend? - by JonE - 03-01-2022, 05:48 PM
RE: rear axle casing bend? - by Hedd_Jones - 04-01-2022, 10:21 AM
RE: rear axle casing bend? - by Howard Wright - 04-01-2022, 10:42 AM
