rear axle casing bend?
If it has been run like that the whole end of the axle shaft would warrant crack testing. Even with the pinion removed the complete  axle is quite heavy to manhandle. Innards can be withdrawn  from the other side, noting recent post on topic.
Hard wooden blocks can be shaped to avoid pressing flats on the axle tube. But without an assortment of heavy angle iron  needs some ingenuity to contain a powerful jack. Have often seen moderat lengths of heavy threaded rod at swap meets etc. Handy for such situations. All my many spare axle houisings got turned into axle stands eons ago.... never occurred to check for bends! Cannot be too rare, but does position of brake cam vary?
Could spend hours trying to straighten and checking  outcome. The axle end spigot has to remain square  to the diff mid split, and  concentric.
Panelbeaters have gear but would need some quick as you go alignment check jig to save time.
Hard to imagine how would occur without backplate and hub damage.
rear axle casing bend? - by JonE - 21-12-2021, 04:27 PM
RE: rear axle casing bend? - by Howard Wright - 21-12-2021, 04:51 PM
RE: rear axle casing bend? - by Malcolm Parker - 21-12-2021, 05:11 PM
RE: rear axle casing bend? - by Stuart Giles - 21-12-2021, 06:20 PM
RE: rear axle casing bend? - by JonE - 21-12-2021, 06:50 PM
RE: rear axle casing bend? - by Reckless Rat - 21-12-2021, 06:55 PM
RE: rear axle casing bend? - by Bob Culver - 21-12-2021, 07:44 PM
RE: rear axle casing bend? - by Ruairidh Dunford - 21-12-2021, 07:46 PM
RE: rear axle casing bend? - by Steve Jones - 21-12-2021, 08:02 PM
RE: rear axle casing bend? - by JonE - 21-12-2021, 08:47 PM
RE: rear axle casing bend? - by Ivor Hawkins - 21-12-2021, 10:25 PM
RE: rear axle casing bend? - by Bob Culver - 22-12-2021, 03:36 AM
RE: rear axle casing bend? - by JonE - 22-12-2021, 10:52 AM
RE: rear axle casing bend? - by Reckless Rat - 22-12-2021, 11:16 AM
RE: rear axle casing bend? - by Hedd_Jones - 22-12-2021, 11:51 AM
RE: rear axle casing bend? - by Stuart Giles - 22-12-2021, 12:04 PM
RE: rear axle casing bend? - by JonE - 22-12-2021, 02:02 PM
RE: rear axle casing bend? - by Ivor Hawkins - 22-12-2021, 04:26 PM
RE: rear axle casing bend? - by JonE - 03-01-2022, 05:48 PM
RE: rear axle casing bend? - by Hedd_Jones - 04-01-2022, 10:21 AM
RE: rear axle casing bend? - by Howard Wright - 04-01-2022, 10:42 AM
