16-12-2021, 07:52 PM
Thanks for your suggestions. My control spindle (Austin's terminology) hits the back of the barrels at about the point where a frost plug is placed.
In my case, the spindle is notched to locate the levers at each end. I will try rotating the spindle to find a happy clear spot and then add new notches to enable the levers to be put at the correct angle again. Much easier than making a new spindle.
Thanks again folks. Wonderful to get overnight help into New Zealand.
Slowly rebuilding a '34 RP
