Accelerator control spindle jams against motor
I had a similar problem with my RP a little while ago. On full right lock, the end of the draglink was lifting the throttle lever at the base of the steering column. It took a bit of resetting the linkage, but, as dickie65 says, slackening the actuating arm pinch bolt on the throttle cross shaft means that all the linkage can be adjusted to get rid of the problem.
RE: Accelerator control spindle jams against motor - by David Stepney - 16-12-2021, 05:54 PM
