16-12-2021, 05:48 PM
Are you refering to the bar that crosses behind the block which has the pedal on one end and the throttle actuating lever on the other ?
If so loosen the pedal pinch bolt and actuating arm pinch bolt and re set the crossbar position then try it again.
The bar is curved in the middle to go over the flywheel cover.
A picture of the problem helps.
