Loose Wheel Bearing
PS Bob, I also liked your idea of a blob of solder at the top of the stub. That's a good place to put the solder because the load will be taken on the bottom of the stub.  However, I would have to use a gas flame to get enough heat into the stub and I was concerned about fire risk in the axle casing where some oil had leaked through. Also I was nervous about using a flame so close to the petrol tank.
Graham
Loose Wheel Bearing - by Graham Barker - 14-12-2021, 12:34 AM
RE: Loose Wheel Bearing - by Bob Culver - 14-12-2021, 04:44 AM
RE: Loose Wheel Bearing - by leaf200 - 14-12-2021, 07:13 AM
RE: Loose Wheel Bearing - by Howard Wright - 14-12-2021, 08:14 AM
RE: Loose Wheel Bearing - by Graham Barker - 14-12-2021, 09:05 AM
RE: Loose Wheel Bearing - by Howard Wright - 14-12-2021, 09:56 AM
RE: Loose Wheel Bearing - by Cliff Ringrose - 14-12-2021, 12:46 PM
RE: Loose Wheel Bearing - by Graham Barker - 14-12-2021, 08:26 PM
RE: Loose Wheel Bearing - by Bob Culver - 14-12-2021, 08:31 PM
RE: Loose Wheel Bearing - by Robert Foreman - 14-12-2021, 08:54 PM
RE: Loose Wheel Bearing - by Hedd_Jones - 14-12-2021, 09:13 PM
RE: Loose Wheel Bearing - by Tony Press - 14-12-2021, 10:58 PM
RE: Loose Wheel Bearing - by Graham Barker - 15-12-2021, 09:32 AM
RE: Loose Wheel Bearing - by Graham Barker - 15-12-2021, 06:49 PM
RE: Loose Wheel Bearing - by Tony Press - 15-12-2021, 09:31 PM
RE: Loose Wheel Bearing - by Dave Mann - 15-12-2021, 10:28 PM
RE: Loose Wheel Bearing - by Tony Press - 15-12-2021, 10:51 PM
RE: Loose Wheel Bearing - by Bob Culver - 16-12-2021, 01:31 AM
RE: Loose Wheel Bearing - by squeak - 16-12-2021, 01:33 AM
RE: Loose Wheel Bearing - by Tony Press - 16-12-2021, 02:56 AM
