Jet feed, pressure feed difference
#27
As a non racer but one who likes a bit of performance , when I rebuilt my engine (2 bearing) I was a little concerned that  the lube system was a bit hit and miss , or should that be mist?   I had read about the duplication of the oil jets and decided  that the belt and braces approach could only improve the lubrication. I routed a new oil  line within the crankcase using copper/nickle brake pipe,made up some jets by peening the ends of the pipe, running a 1.5mm drill through to give a straight stream of oil. spent some time aiming the four jets at the  "bath tub" collectors on the crank. A bit messy but worthwhile. With a standard oil pump I have ,when hot and cruising at normal traffic speeds, 2 to 5 psi showing on the gauge. I did not fit the bore oil plates and don't have what I would consider excessive oil consumption .
RE: Jet feed, pressure feed difference - by Spex - 09-12-2021, 10:50 PM
RE: Jet feed, pressure feed difference - by Roger - 10-12-2021, 04:51 PM
RE: Jet feed, pressure feed difference - by Peter Clayton - 10-12-2021, 09:55 PM
