Jet feed, pressure feed difference
#23
If a two stroke engines can run successfully on 50:1 mix in the petrol then surely as Ruairidh says an Austin Seven system is supplying more than enough under normal circumstances.
Roger
RE: Jet feed, pressure feed difference - by Spex - 09-12-2021, 10:50 PM
RE: Jet feed, pressure feed difference - by Roger - 10-12-2021, 04:51 PM
