Jet feed, pressure feed difference
This is a phoenix splash fed crank. The oil is squirted from two jets in the oil gallery into the two hollows which direct it through to the big end bearings
[Image: BB45small.jpg]
This is a pressure fed crank (a three bearing one from a Nippy) - the hollows are covered over and the oil is fed through the crankshaft from the front of the engine.
[Image: a7-engine1.jpg?w=1280&h=768&crop=1]
Hope that helps.
RE: Jet feed, pressure feed difference - by Reckless Rat - 09-12-2021, 09:57 PM
RE: Jet feed, pressure feed difference - by Spex - 09-12-2021, 10:50 PM
RE: Jet feed, pressure feed difference - by Roger - 10-12-2021, 04:51 PM
