  • 2 Vote(s) - 5 Average
Smart Diode Cut-out - experience of use?
(03-12-2021, 01:00 PM)Howard Wright Wrote: Hi Tony
I’ve had one on the Special for the last 1000 miles. Seems to work OK. Easy to fit and goes under the cover of the fuse part of the cut out.
PS I have one in the spares box in my RK as you never know when the electromechanical cut out will pack up.
Thank you, Howard. To what terminals do the two leads attach - or is that obvious when the unit is removed from the bulkhead?
RE: Smart Diode Cut-out - experience of use? - by Tony Griffiths - 03-12-2021, 04:40 PM
