rear axle cotter pin design difference?
hi jonE,
im not sure if people will see whats wrong.
if you meen the thread of the new ones are in the centre of the cotter, rather than offset to the edge. so the taper can be cut properly.
then yes, the new ones are made WRONG.
the thread should be offset.
as ian says. there were originally 3 different lengths, brake arm, rear spring pin, cross shaft.
tony
rear axle cotter pin design difference? - by JonE - 29-11-2021, 02:34 PM
RE: rear axle cotter pin design difference? - by Tony Betts - 29-11-2021, 06:20 PM
