larger updraft carbs?
(20-11-2021, 10:22 PM)JonE Wrote: Ian - agree, but I just think the 1 1/4 looks too modern even though it's the easiest route. And I've got a finally-restored OM unit sitting here. I spoke to John Barlow today who has some steel flanges so even if I have to make an additional 1" one up myself, it shouldnt be too difficult to weld up to add to the log manifold. (Howard has done the entire thing in aluminium as a pleasing single bespoke manifold, but I can't find the wall thickness he used  - I don't want a carb hanging on 1.6mm aluminium tube).
Henry's updraft Solex idea - are around but expensive so not worth pursuing.
Hi Jon
From memory the aluminium tube I used was 2mm. I paid around £30 to get it TIG welded. The carb is a 1 1/4” H2. Currently running a GG needle and blue spring.
larger updraft carbs? - by JonE - 19-11-2021, 09:07 AM
RE: larger updraft carbs? - by Howard Wright - 19-11-2021, 09:26 AM
RE: larger updraft carbs? - by Henry Harris - 19-11-2021, 09:54 AM
RE: larger updraft carbs? - by Bob Culver - 19-11-2021, 10:01 AM
RE: larger updraft carbs? - by Parazine - 19-11-2021, 10:18 AM
RE: larger updraft carbs? - by JonE - 19-11-2021, 11:57 AM
RE: larger updraft carbs? - by Parazine - 19-11-2021, 01:01 PM
RE: larger updraft carbs? - by Ian Williams - 19-11-2021, 07:50 PM
RE: larger updraft carbs? - by JonE - 20-11-2021, 10:22 PM
RE: larger updraft carbs? - by Howard Wright - 20-11-2021, 10:49 PM
RE: larger updraft carbs? - by Ian Williams - 21-11-2021, 07:15 AM
RE: larger updraft carbs? - by JonE - 21-11-2021, 09:15 AM
RE: larger updraft carbs? - by Ian Williams - 21-11-2021, 10:02 AM
RE: larger updraft carbs? - by JonE - 21-11-2021, 03:04 PM
RE: larger updraft carbs? - by Bob Culver - 21-11-2021, 11:31 PM
RE: larger updraft carbs? - by JonE - 23-11-2021, 09:15 AM
