Rear axle diff seals
Thanks  for replies.
I have two 1.5mm cross section O rings on the way from ebay. I am hoping that they will reduce the fight to get the clips in . I've also made a device like a small piston ring compressor from some shimming and a jubilee clip.
If I fail I may get back to you Martin , and take you up on your kind offer.
Rear axle diff seals - by scrooge - 17-11-2021, 02:10 PM
RE: Rear axle diff seals - by Chris KC - 18-11-2021, 11:37 AM
RE: Rear axle diff seals - by Martin Baker - 19-11-2021, 12:59 PM
RE: Rear axle diff seals - by scrooge - 20-11-2021, 09:58 AM
RE: Rear axle diff seals - by scrooge - 21-11-2021, 12:07 PM
