larger updraft carbs?
Thanks for the Zenith thoughts. I think as I don't need to stay standard looking for the Gould body, I also need the ease but want to get to at least 18mm choke which I don't think the 24T will do? If I bore out, I have to think about jetting...
I've already got Howard's Special images where he has created a bespoke inlet from a damaged upended downdraft and a new alloy stub for a 30 degree SU... but i'm just trying to think simplicity (and no alloy welding).
Henry - I've got a horizontal OM 1" ready to use, but would you adopt Howard's route, or have you made a secondary converter for such? I'll have a search on the Solex... thanks.
larger updraft carbs? - by JonE - 19-11-2021, 09:07 AM
RE: larger updraft carbs? - by Howard Wright - 19-11-2021, 09:26 AM
RE: larger updraft carbs? - by Henry Harris - 19-11-2021, 09:54 AM
RE: larger updraft carbs? - by Bob Culver - 19-11-2021, 10:01 AM
RE: larger updraft carbs? - by Parazine - 19-11-2021, 10:18 AM
RE: larger updraft carbs? - by JonE - 19-11-2021, 11:57 AM
RE: larger updraft carbs? - by Parazine - 19-11-2021, 01:01 PM
RE: larger updraft carbs? - by Ian Williams - 19-11-2021, 07:50 PM
RE: larger updraft carbs? - by JonE - 20-11-2021, 10:22 PM
RE: larger updraft carbs? - by Howard Wright - 20-11-2021, 10:49 PM
RE: larger updraft carbs? - by Ian Williams - 21-11-2021, 07:15 AM
RE: larger updraft carbs? - by JonE - 21-11-2021, 09:15 AM
RE: larger updraft carbs? - by Ian Williams - 21-11-2021, 10:02 AM
RE: larger updraft carbs? - by JonE - 21-11-2021, 03:04 PM
RE: larger updraft carbs? - by Bob Culver - 21-11-2021, 11:31 PM
RE: larger updraft carbs? - by JonE - 23-11-2021, 09:15 AM
