Rear axle diff seals
I wondered if anyone had an easy way of putting the spring retainer into each half of the diff casings on  the D type axles. I'm using a modern seal and a thin O ring under the seal cup . I use a length of threaded bar to pull the plate on the seal and the assembly bellow the retaining spring groove , but i always have a battle getting the spring clip in.
Normal involves many screwdrivers and not enough hands.
Rear axle diff seals - by scrooge - 17-11-2021, 02:10 PM
RE: Rear axle diff seals - by Chris KC - 18-11-2021, 11:37 AM
RE: Rear axle diff seals - by Martin Baker - 19-11-2021, 12:59 PM
RE: Rear axle diff seals - by scrooge - 20-11-2021, 09:58 AM
RE: Rear axle diff seals - by scrooge - 21-11-2021, 12:07 PM
