Scraping White Metal
If the existing crank has been ground and the new one is standard size, that is likely to be an awful lot of scraping; typically crank grinds are done in 0.010" (10 thou') increments, your crank could easily be '30 under' or more. Whereas each scraper stroke gives a 'peeling' of about 0.0001" ( one ten thousanth). The big ends can be bored in a milling machine or (by using a simple jig) on a lathe to size, leaving no, or minimal scraping to get a good final fit. An 'old school' machine shop or any decent jobbing engineer should be able to do that boring for you.
Scraping White Metal - by Chris.Dallas - 17-11-2021, 01:04 AM
RE: Scraping White Metal - by Bob Culver - 17-11-2021, 01:21 AM
RE: Scraping White Metal - by Ian Williams - 17-11-2021, 03:30 AM
RE: Scraping White Metal - by Colin Reed - 17-11-2021, 04:45 AM
RE: Scraping White Metal - by GCD - 17-11-2021, 10:07 AM
RE: Scraping White Metal - by Stuart Giles - 17-11-2021, 11:33 AM
RE: Scraping White Metal - by Chris.Dallas - 17-11-2021, 12:03 PM
RE: Scraping White Metal - by AustinWood - 17-11-2021, 01:34 PM
RE: Scraping White Metal - by Chris.Dallas - 17-11-2021, 01:54 PM
RE: Scraping White Metal - by Steve Jones - 17-11-2021, 02:12 PM
RE: Scraping White Metal - by Chris.Dallas - 17-11-2021, 07:33 PM
RE: Scraping White Metal - by Bob Culver - 18-11-2021, 06:44 AM
