Steering problem
If overtightened nut was problem then do nut up till just before any freedom is lost then continue to tighten till loss of movement and count amount of turn(s).  Using the TPI (threads per inch)  on the inner column you can then determine the amount of movement of the wheel down the column and that amount, or just a little more can be taken off the top of the outer column so wheel no longer touches.
Dennis
Steering problem - by Malcolm Parker - 15-11-2021, 12:14 PM
RE: Steering problem - by Austin in the Shed - 15-11-2021, 12:50 PM
RE: Steering problem - by Dennis Nicholas - 15-11-2021, 05:26 PM
RE: Steering problem - by Steve Jones - 15-11-2021, 05:55 PM
RE: Steering problem - by Dennis Nicholas - 15-11-2021, 06:25 PM
RE: Steering problem - by Ruairidh Dunford - 15-11-2021, 09:48 PM
RE: Steering problem - by Malcolm Parker - 15-11-2021, 10:12 PM
RE: Steering problem - by Steve Jones - 16-11-2021, 01:20 PM
RE: Steering problem - by Malcolm Parker - 16-11-2021, 01:51 PM
RE: Steering problem - by Steve Jones - 16-11-2021, 03:30 PM
RE: Steering problem - by Malcolm Parker - 16-11-2021, 04:05 PM
RE: Steering problem - by Martin Nash - 01-09-2024, 06:13 PM
RE: Steering problem - by Malcolm Parker - 01-09-2024, 07:14 PM
RE: Steering problem - by Martin Nash - 02-09-2024, 12:37 PM
