Touring piston oil ring "coiled wire"
#26
Two have now confirmed that on the touring Seven pistons, these ring springs that come in the sets definitely do not allow a fit (i.e. for both ring spring and oil control ring) in the bore. So if you buy any, just respect the typed note, but that is the reason!
For novices like me, rings are also pre-gapped, so worth bearing in mind if you are contemplating trying to re-assemble between rebores rather than do a complete rebuild.
Touring piston oil ring "coiled wire" - by JonE - 07-11-2021, 09:31 AM
RE: Touring piston oil ring "coiled wire" - by JonE - 11-11-2021, 11:05 AM
