2 QUESTIONS.
Hi
On my bog standard 2 bearing RK the gauge goes off the scale on start up but when hot (several miles on) registers zero on tickover and about 3 to 5 psi at 2000+ revs.
On my special with a bored out pump it registers about 25 psi on start up, 5 psi on tickover when hot and about 10 psi at 2500 revs.  I fitted a 30 psi gauge and have a T’d connection in the pipe to a switch that registers when the pressure exceeds 14psi. This lights a panel light as an extra warning of a blocked jet.
Coiling the oil pipe just provides some flexibility between the engine and gauge. On the special I’ve switched to a plastic pipe.
I wish I could get to the release valve as I have a small leak coming from it  Angry.
2 QUESTIONS. - by Rpm - 09-11-2021, 09:40 PM
RE: 2 QUESTIONS. - by Chris KC - 09-11-2021, 09:54 PM
RE: 2 QUESTIONS. - by Peter Naulls - 09-11-2021, 10:06 PM
RE: 2 QUESTIONS. - by Mike Costigan - 09-11-2021, 10:17 PM
RE: 2 QUESTIONS. - by Rpm - 09-11-2021, 10:20 PM
RE: 2 QUESTIONS. - by Malcolm Parker - 09-11-2021, 10:33 PM
RE: 2 QUESTIONS. - by Rpm - 09-11-2021, 10:39 PM
RE: 2 QUESTIONS. - by Chris KC - 09-11-2021, 11:46 PM
RE: 2 QUESTIONS. - by Bob Culver - 09-11-2021, 11:55 PM
RE: 2 QUESTIONS. - by Tony Griffiths - 10-11-2021, 01:44 AM
RE: 2 QUESTIONS. - by John Mason - 10-11-2021, 10:12 AM
RE: 2 QUESTIONS. - by Mike Costigan - 10-11-2021, 10:22 AM
RE: 2 QUESTIONS. - by Chris KC - 10-11-2021, 10:29 AM
RE: 2 QUESTIONS. - by Bob Culver - 10-11-2021, 10:38 AM
RE: 2 QUESTIONS. - by Dave Wortley - 10-11-2021, 11:48 AM
RE: 2 QUESTIONS. - by Howard Wright - 10-11-2021, 12:03 PM
RE: 2 QUESTIONS. - by Dennis Nicholas - 10-11-2021, 02:42 PM
RE: 2 QUESTIONS. - by Malcolm Parker - 10-11-2021, 11:49 PM
RE: 2 QUESTIONS. - by Chris KC - 11-11-2021, 09:18 AM
RE: 2 QUESTIONS. - by Malcolm Parker - 11-11-2021, 09:50 AM
RE: 2 QUESTIONS. - by Colin Cooke - 11-11-2021, 10:23 AM
