Replacng rear axle assembly
To remove an axle, the worst job is getting the spring pin cotter pin out. So you can then remove the spring pin, which can also be a chore, if its been there a long time and your hubs are still on.
If you plan fitting new springs (as I am about to do shortly on one of my cars), I find the easiest way is to lop the bottom leaf of the spring with an angle grinder. You can then deal with the cotter, and the spring pin on the bench, rather than on your back under the car. Clearly don't do this if you want to keep the springs.
When I do this job, I make sure the springs are loose in the chassis for when I put the axle in.
By that I mean I have the springs in, and the vertical bolt in, but its loose and the U bolts also loose.
Rarely are the springs an interference fit in the chassis (unless they' ve not been out in 50 years!), so with a little clearance, you get a good bit of waggle at the axle end of the spring, which in turn helps you get the pins in.
A large shifter (shifter = Adjustable spanner) is also very useful, as sometimes you need to twist the bottom leaf a smidge to get the spring pin in. The other solution to this problem is to grind a lead on it and fit it with a course persuader.
Personally I don't worry too much about wear on the the eyes on the axle so long as they are strong enough to do the job. The geometry of the rear suspension on an Austin 7 is a total mess. As the springs flatten, the axle end of the spring goes backwards and out (in plan looking from above).
If you assumed the springs fitted perfectly in the axle eyes, and the pin the same with no clearance, and that the spring was solid in the chassis, assuming the chassis itself is rigid. So when the axle moves relative to the chassis the spring wants to do all sorts of things that the chassis and spring pin and axle ears try to stop it. My view is even if you had it all perfect on assembly, within a couple of hundred miles it will have worn itself the necessary clearance needed to operate how it does in the real world. For this reason the torque tube is basically a ball on a link. The axle rotates around the ball, which is in itself not a fixed point because of the link.
As I said, total mess.
Replacng rear axle assembly - by SneezerUSA - 06-11-2021, 05:53 PM
RE: Replacng rear axle assembly - by Chris KC - 06-11-2021, 07:35 PM
RE: Replacng rear axle assembly - by Bob Culver - 06-11-2021, 07:57 PM
RE: Replacng rear axle assembly - by Chris KC - 06-11-2021, 08:09 PM
RE: Replacng rear axle assembly - by Stumpi - 06-11-2021, 08:45 PM
RE: Replacng rear axle assembly - by Alan - 06-11-2021, 09:17 PM
RE: Replacng rear axle assembly - by Bob Culver - 07-11-2021, 05:45 AM
RE: Replacng rear axle assembly - by SneezerUSA - 07-11-2021, 08:59 PM
RE: Replacng rear axle assembly - by Bob Culver - 07-11-2021, 09:16 PM
RE: Replacng rear axle assembly - by SneezerUSA - 08-11-2021, 04:20 PM
RE: Replacng rear axle assembly - by Hedd_Jones - 08-11-2021, 04:57 PM
RE: Replacng rear axle assembly - by SneezerUSA - 09-11-2021, 02:31 AM
RE: Replacng rear axle assembly - by Tony Press - 09-11-2021, 02:40 AM
RE: Replacng rear axle assembly - by SneezerUSA - 09-11-2021, 03:01 AM
RE: Replacng rear axle assembly - by Bob Culver - 09-11-2021, 06:00 AM
RE: Replacng rear axle assembly - by SneezerUSA - 11-11-2021, 11:42 PM
RE: Replacng rear axle assembly - by Bob Culver - 12-11-2021, 01:24 AM
RE: Replacng rear axle assembly - by SneezerUSA - 12-11-2021, 01:34 AM
RE: Replacng rear axle assembly - by SneezerUSA - 12-11-2021, 02:40 AM
RE: Replacng rear axle assembly - by Chris KC - 12-11-2021, 09:08 AM
RE: Replacng rear axle assembly - by SneezerUSA - 12-11-2021, 03:18 PM
