Replacng rear axle assembly
Also found....the inner faces of the lugs on the axle casing, that the spring pins go through, not parallel due to wear (just like the inner thrust faces on the stub axles). I spent quite a while filing up wedge shaped washers/shims to fit and take up side wear between spring eye and lugs. (oh to have a surface grinder with adjustable bed or vice)
Dennis
Replacng rear axle assembly - by SneezerUSA - 06-11-2021, 05:53 PM
RE: Replacng rear axle assembly - by Chris KC - 06-11-2021, 07:35 PM
RE: Replacng rear axle assembly - by Bob Culver - 06-11-2021, 07:57 PM
RE: Replacng rear axle assembly - by Chris KC - 06-11-2021, 08:09 PM
RE: Replacng rear axle assembly - by Stumpi - 06-11-2021, 08:45 PM
RE: Replacng rear axle assembly - by Alan - 06-11-2021, 09:17 PM
RE: Replacng rear axle assembly - by Bob Culver - 07-11-2021, 05:45 AM
RE: Replacng rear axle assembly - by SneezerUSA - 07-11-2021, 08:59 PM
RE: Replacng rear axle assembly - by Bob Culver - 07-11-2021, 09:16 PM
RE: Replacng rear axle assembly - by Dennis Nicholas - 08-11-2021, 03:15 PM
RE: Replacng rear axle assembly - by SneezerUSA - 08-11-2021, 04:20 PM
RE: Replacng rear axle assembly - by Hedd_Jones - 08-11-2021, 04:57 PM
RE: Replacng rear axle assembly - by SneezerUSA - 09-11-2021, 02:31 AM
RE: Replacng rear axle assembly - by Tony Press - 09-11-2021, 02:40 AM
RE: Replacng rear axle assembly - by SneezerUSA - 09-11-2021, 03:01 AM
RE: Replacng rear axle assembly - by Bob Culver - 09-11-2021, 06:00 AM
RE: Replacng rear axle assembly - by SneezerUSA - 11-11-2021, 11:42 PM
RE: Replacng rear axle assembly - by Bob Culver - 12-11-2021, 01:24 AM
RE: Replacng rear axle assembly - by SneezerUSA - 12-11-2021, 01:34 AM
RE: Replacng rear axle assembly - by SneezerUSA - 12-11-2021, 02:40 AM
RE: Replacng rear axle assembly - by Chris KC - 12-11-2021, 09:08 AM
RE: Replacng rear axle assembly - by SneezerUSA - 12-11-2021, 03:18 PM
