braided strap amp capacity for dynamo earth brush
I've noticed that the little braided straps for the earth brush on the late Seven dynamos are often quite old and deficient.
The braid seems to be 15A - about the 3mm width the originals might have been when new as its quite tight for space in there. If one is going to dispense with third brush at 6V, should this wire be upped in size or will that 15A spec do fine just to restore what should have been?
braided strap amp capacity for dynamo earth brush - by JonE - 07-11-2021, 02:03 PM
